U
Unruely
I have a '94 D1 i purchased about a month ago, with 144,000 miles on it.. When I bought it it had a miss, so I changed the plugs, wires, rotor button and distributor cap. That took care of the miss, but when cold it is difficult to start. I have to crank the starter for at least 10-15 seconds before it will begin to hit, sometimes I think it helps to give it a little gas while cranking.. I am debating changing the coil and possible the elec. module, but am not certain I am heading in the right direction.. I still have to check the timing also. When the engine is warm, if I shut it off for 5 minutes or less, it will start right up within a few seconds, but if it has set overnight or even 30 minutes or so, it takes a lot of cranking to get it to fire... This morning after it set all night I held the gas pedal to the floor before trying to start it, it fired up instantly. Before i start changing out more parts I thought I would ask for some opinions???
Thanks for your help.
Martin
Martin
