Help! Its Smoking!
jlglr4
Northern California
What year? If its the v8, might well be the vacuum pump. Been reported on these forums a few times. It’s connected to the intake via vacuum hose. When it goes bad, oil is sucked straight from the pump/crankcase into the intake.
If its an scv6, could be the supercharger bypass is stuck closed. I know someone on here had that problem once and it was sucking a bunch of oil into the intake under wot, i guess through the crankcase vent/pcv.
On either engine, a totally ripped pcv valve might let oil into the intake under high backpressure conditions.
ttforcefed
2013 and just had this replaced
ttforcefed
ok looks like i need to have the valve stems done - any idea how big of a job ballpark? will go to an independent.
powershift
Nevada
I've done valvestem seals on a small block pushrod V8 and it wasn't hard but you have to be careful that you don't drop the keepers or the valves down into the cylinder.
Rover Range
Texas
Valve stem seal failures are extremely rear.
A leaking valve stem seal would only show up on engine deceleration, like exiting a freeway ramp. i.e. high engine vacuum.
ttforcefed
more to come - theyre gonna see if the vacuum pump is still pushing oil into intake.
Rover Range
Texas
I had one a couple months ago. Was guzzling five qts of oil in a 1,000 miles.
Ended up needing an engine. Piston rings were shot.
ttforcefed
did you go with a new engine? did you get quoted for the cost of an engine rebuild?
