Help lr3 has dropped all the way
Rover Bull, I think it makes a heckuva lotta sense to replace that switch. Can you make a recording of the noise from the front right. There is a valve body there under the splash shield. Basically, it takes air from the compressor and sends it to the two front air springs.
I'm wondering also if your codes don't need to be cleared now that you have a new compressor.
Rover bull
Sure thing will do, and if this part you are talking about is bad is it able to disable the whole suspension assembly? Also got my original compressor checked guy said it was still good. Will a compressor not work on a lr3 if the codes are not erased? I also did replace the switch no change.
