hi, new guy here.
c.j.arditoiii
own a 93 county LWB with the 4.2 litre. on cold mornings notice a puddle of antifreeze just behind the front axle. dealer says intake manifold is leaking and thehead gaskets show that they are starting to leak. estimate is $2500 to fix. i LOVE my truck, however, thats alot of $.
rover is in pretty good shape otherwise, considering 130,000 miles. should i do the repair? please advise with any thoughts. thanks.
If you do decide to do the work... and it probably needs it... do not take it to the dealer....
Remember the engine is basically a 1960 Buick 215ci engine... any good mechanic should be able to do this work for less than $500.
For $2500 I would expect a complete rebuild.
97rover
the price is pretty accurate for a rebuilt. When you mention Landrover or any forein car to a regular mech they normal seize up but the Rovers aren't that hard to work on. you have to remind them that it is a normal engine.
sandman
heres an idea, check the fan and waterpump to see if its loose.
if the water pump pulley is loose its an new waterpump.
seen it happen a few tiems, they get loose and loose a bit at time.
Tumbler
