IID Tool Adjustments
xrp86
Mcallen
Hello, just got my iid tool mainly to adjust my lr's hight.
What else have you guys done with this tool, apart from diagnosing faults??
Troy A
San Francisco, CA
Added keys. Turned off the TPMS. Used it on long trips to track engine metrics in real-time to watch for overheating issues.
TrinidadLR4
NE Washington DC
I turned off TPMS. It took some work as you gotta do it in three separate places. Where can you add the digital speedo?
Nechaken
Colorado
I think under in the CCF bit, under IPC (instruments) there's an entry called "Digital Speed" or something similar.
xrp86
Mcallen
What PSI are you running, what was your main reason for turning TPM Off?
Ive been thinking of dropping the psi like the new D5, which have 2 options.
Light load
Regular load (I think that’s what it’s called)
Troy A
San Francisco, CA
Light load
I have E-rated tires (80psi capable) and run them at 50 on the freeway, and then step down as needed off-road (38, 33, 25).
I also use external TPMS sensors that are more easily moved around so that every time I do a five wheel rotation I don't need to worry about moving my 4 LR TPMS valves/sensors and reconfiguring anything. There were many discussions elsewhere here in the forum on external TPMS sensors if you search for them.
With the external sensors sending the data to a little gauge, I can constantly see the tire pressure in real time on the four wheels which is handy. And it has a built in alarm for too rapid inflation/deflation. With all that, there is no need to have the internal TPMS notifications on the screen.
TrinidadLR4
NE Washington DC
I disabled mine because I got new wheels and I didn't want to reconfigure the tpms sensors to work with them. The TPMS system in this vehicle is garbage anyway as doesn't display PSI readings. Newer ones might.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
I've done quite a bit with the tool. I messed with the CCF to disable tpms, new battery, DRL (didn't work), and some other thing. Calibrated ride height sensors, ride height adjustments, tight tolerance (alignment), build mode (similar to pulling fuse F3 to lock the eas system while off roading), reading live values, etc...
These are just some of things off the top of my head. I'm sure I've done a lot more with it.
