lift kit suggestions please
widepud
yeah its a daily driver and i do play on trails pretty regularly w it. im kinda going the lift route since the suspension is sagging a bit anyway and for a little more than replacing it w stock parts i figured id just get a lift for it. plus my tires rub when turned all the way at low speeds
Va_Disco
If your suspension is sagging bad you are right about just doing the lift now. You may also want to think about replacing your bushings while you have everything apart. Where are your tires rubbing, just lifting your rover may not solve the rubbing issue you may need to look into wheel spacers.
MArsel
