Loud clunk while turning steering wheel
markdrm1
Hey all,
My 99 disco is making a loud clunk when I turn the steering wheel. Sounds like its getting worse. Any Ideas?
Mark
is this clunk at slow speeds? if so, it may be CV joints. If a higher speeds and you feel it in the steering wheel it could be Panhard rod bushings.
markdrm1
Its happening at a slow speed, especialy when turning sharp.
Thanks,
Mark
Sounds like a CV joint starting to go. Should be to hard to fix... Mine has been making noise for about 10k miles... I figure before this year is out I need to change it. Or at least pull it apart and reverse the cage and get another 40k miles out of it.
Muddyone
Land Rover Sales Consultant
Waterloo
Mine has been doing it at low speeds and today has just come apart! Luckily I was at a stop sign making a turn and it broke half way through, so I was pretty much stuck in the middle of the intersection. Now is this something that is hard to fix? The part that has separated controls the rod that moves the tires. It looks like the rubber ****** has broken off and there is no lube only dust in the joint. Is it just a case of replacing the rubber ****** or……….
Muddyone
Waterloo
Here is a pic of the broken ******...
Muddyone
Waterloo
So do i just need a CV Boot Kit, are there any instructions on how to replace this?
What you have is a broken ball joint.... I would look at replacing them all while you are in there.
Muddyone
Waterloo
So should i replace the whole rod... any instructions? How do i get the broken bolt out?
No need to replace the whole rod that I am aware of.... I will look for instructions, broken bolt... pain.
PE_in_UAE
