LR3 Tailgate noise
roverman
Sounds like the rubber seal is rubbing and causing the squeak. I think you need to have the latch mechanism adjusted to pull the tailgate in tighter. I'm not 100% on this as it was a 4 years ago but I think this is what the dealer did to cure it.
lvv
Thank you
do you know how to adjust it
Maybe you have manual???
roverman
I do not have the manual, i had the dealer do it under warranty. Hopefully someone else can help. And to everyone else, try going onto a forum that isn't in your native language to get some help and see how much you like being mocked.
ralph
Same noise, I greased the rear tail gate hinges and the rubber with white lithium and no more noise.
MArsel
