LR4 Gear Change Whine
Austin Fink
Atlanta, GA
Here's a new one, when I switch gears from Drive > Neutral > Reverse, or Park > Reverse, I hear a loud gear like whine, almost like when you disengage the parking break but much louder. Has anyone had this issue before, or any ideas. I can't tell if it's the transmission itself, or maybe even the transfer case. Also possibly related, when i put the car in park, the gear selector indicator on the dash with flash, so the P will essentially blink. Anyone?
Azoo
Brampton Ontario
Strange problem and no Idea what it might be. if i had this kinda issue i would try several things with the hope that one might work, so i would disconnect the battery, or maybe drive in manual mode for a few minutes, or change the drive mode setting for snow, sand etc. Basically just try random things and you might just be lucky the noise goes away.
Austin Fink
Atlanta, GA
I've noticed its only when its cold or the engine has been running a few minutes. It's very strange. I've been looking it up, it could be a sensor in the transmission, but no codes yet. I'm just hoping its nothing serious.
