I sometimes debate doing this, and I've done some research but havent found that much that's conclusive. I was going to post this in other threads people had, but I didn't want it to seem like I was bombing their threads, and since I've just got info on parts compatibility, maybe its best for to be its own thread for people to find.
Since I have a 2016 LR4, this is focused mostly on compatibility with that model. I have included earlier LR4 info when I've found it in my research. I know some stuff is compatible, but IDK how much is. I've been told by others on here that the listings in the parts info searcher on Rover Dealer Parts isn't perfect. So maybe there's more that's compatible than what they show.
Best I've found here's the short list of what's needed.
- In Dash Control Panel
- 2 Speed Transfer Case
- Locking Rear Diff
- Rear HD Axles
- Transfer Case Module
- Differential Module
- ? 2 Speed Transfer Case Harness
- ?Differential harness
(Updated as of 22 Nov 25)
I've found very little with regard to the wiring side of things. I know there's some compatibility with other JLR models, but how much seems to vary greatly from model to model. So I've included what I've found in case its helpful for someone.
In Dash Control Panel (2014-2016 L319)
EH22-14B596-AB
Early LR4:
AH22-14B596-AD (2013 L319)
AH22-14B596-AC (Early L319)
2 Speed Transfer Case (LR089531, LR052611)
CPLA-7K780-BA (Pulled from a 2016 L319)
CPLA-7K780-BA (Pulled from a 2014 L405)
I've also found these that visually appear identical:
cpla-7k780-ab (Pulled from a 2013 L320)
4H22-7K780-CA (Pulled from a 2010 L320)
Locking Rear Diff (LR050892 LR050896) (LR017322 on 2010-2013 LR4s)
EH22-4W063-BA (Pulled from a 2016 L319)
AH22-4W063-EC (pulled from a 2011 L319)
7H42-4W063-EC 2007-2009 L322
Transfer Case module (LR053307)
I have not found one from a 14-16 L319 yet to get a part number
I've found these but idk if either would be correct
DPLA-7H417-BA
EH22-7H417-AA (European Diesel)
AH42-7H417-AE (2013 L319)
Diff Module (LR083860 LR019427 LR034525 LR043140 LR057232) (13-16 L320,L319,L405)
EX53-4C118-AS (Listed in this Post)
I've also found:
9W83-4C016-AD (listed as 10-13 L320)
9W83-4c118-ba (listed as 10-13 L320)
cpla-4c118-ba (listed as 10-24 L320)
hx53-4c118-AA/AD (10-24 L405)
Differential Harness: (EDIT: After further research I'm not exactly sure if this is a part of the main body harness but can be disconnected or if its something else.)
BH32-14M401-DB (2011 L319)
CH22-14M401-DB (2014 L319)
Others:
BH32-14M401-BC (2011 L320)
AH42-14M401-CB? (2012 L405)
DK62-14M401-CE (2014 L405)
GPLA-14M401-BB (2016 L405)
8 Speed Transmission harnness with 2 Speed Transfer case: LR053087 or LR053088
L319:
BH32-7C078-AA (2010-2013)
EH22-7C078-EC (2014-2016) (I think this is without the Transfer case, but I'm not 100% sure.)
Others:
BH32-7C078-AA (L320)
8H32-7C078-DA (L320)
HPLA-7C078-?? (L405)
DK62-7C078-EC (L405)
Right Rear HD Axle
LR072071 LR047285
Left Rear HD Axle
LR072063 LR047284
Harness with the Rear Axle Locker plugs:
This is a bit more complicated. It seems this is integrated into the main body harness.
Main Harness w/Locking: LR071565 (maybe also LR071540)
Non Locking: LR071566
Unknown: LR071567, LR071568
2010-2013 L319 have the following harnesses; LR015852, LR021136, LR029812, for vehicles with a locking diff.
- Locking Rear Diff
- Rear HD Axles
EH22-14B596-AB
Early LR4:
DPLA-7H417-BA
I've also found:
Others:
L319:
Others:
Right Rear HD Axle
LR072071 LR047285
Left Rear HD Axle
LR072063 LR047284
