LR4 - Reset Service Indicator
kernie
Have started changing my own oil and recently had the Service Indicator light illuminate. Not finding a lot of info on how to reset without the tool.
However I found this last night on a site out of the UK.
Was going to try tonight - but curious if anyone had tried this and been successful.
Mine is a 2010 LR4
Disconnect the battery with the lights on
Press the horn for 5 seconds
This is supposed to erase the code
Reconnect battery and code should be removed
Thoughts?
Try it out and see... I would be weary of disconnecting the battery with the headlights still on (you are supposed to wait at least 2 minutes after turning off the ignition before disconnecting the battery, to avoid issues with electronic modules not shutting down properly.) And press the horn for 5 seconds after the battery is disconnected? What the heck is that going to do? Or is it with the battery reconnected, in which case your family and neighbors will probably hate you? :biggrin:
I'd be amazed if that actually worked, but you never know with these cars. I reset my SII using IIDTool, and didn't think it was possible to reset it without some type of compatible diagnostic system.
Ngomac
