P
pete2528ca
So I pulled out the MAF yesterday, and cleaned it good. There was lots of oily crap on the screen. When I took it out I noticed that there was no O ring, so I used some Loctite gasket maker and just put some on both ends and put it back together again, as the stealership wanted $16 for an O ring. I noticed a major improvement in the engines performance by doing this and cleaning the TPS and Idle sensor. My question is, should there have been an O ring in place? Will the Loctite cause any problems? Its the blue stuff that is silicone based and peels when dry. After I did it I thought maybe I should have just used some grease or oil to make a seal. Now, should I be hearing a little hissing noise from the airbox? I don't know if it was doing it before, or is it because now there is unrestricted airflow going into the engine?
Pietro
Pietro
