Blathering1
- Joined
- May 24, 2010
- Posts
- 17
- Reaction score
- 0
The manual refers to a setting 'Enable mirror dip' for when you shift to reverse. It explains that you set the side mirrors angle while in Reverse, and every time you shift to reverse the mirror shifts to the stored setting. You need to enable this option in settings it indicates.
I have not seen it in the setting options on the speedometer area LCD display. Is this only on certain LR4 options packages, or perhaps it is a dealer enabled option?
