more odd sls stuff
H
happycars
Hi,
I hope someone can help me. I have a 2000 Series 2 and have not had any problems with it until now. It has 98k on it. Recently, on occasion, after being parked for at least an hour, the rear end sits down. It appears to me the passenger side that goes down, as the drivers side stays relatively normal. I would account this to a leaky bag, but it only does it on occasion. Also, if we raise the rear height with the button on the dash, it stays up and never sits down. There are no lights illuminated in the instrument cluster, and again, it only happens every now and then. My mechanic found no leaks in the bags. Any ideas? Thanks for the help!
It probably isn't the bags, but a distribution block or pressure valve.... cheap fix would be to remove SLS and install springs....
Expensive fix, take it to a LR mechanic and spend your next 3 paycheck figuring it out and getting it fixed. then next year bring it back for same issues.
Can you tell I don't like SLS.
BCNJ
