New Crankshaft Sensor bad?
GregDisco2
Alabama
Hey guys,
I was wondering if someone else has seen this same issue. I have. 2001 Discovery 2 with 135,000 miles on it. About a week ago it just died. It turns over but will not hit. After reading, it seemed the most common symptoms resembled the crankshaft sensor issue. I changed it and all good for a week. Now it has died agin. Same issue, turns over but doesn't hit. I pulled a spark plug and smell gas and get spark when it turns over. I read somewhere that when it turns over I should be seeing the rpm needle move a little, even if not hitting, but it just stays on zero. I'm wondering now if the new sensor died, or if anyone else has seen something similar. I hate to change the sensor again. Thanks to anyone that can help out or lead me in the right direction.
Does it have a check engine light? If so, what codes are showing up?
GregDisco2
Alabama
Thanks for the reply. No codes are showing. I scanned with an ICarSoft LR V2.0. The 3 amigo lights are on and the check engine light. The check engine light goes out when I try to crank.
GregDisco2
Alabama
I was thinking about changing the CKP again. Does it make sense it would be bad after only a week? The symptoms are exactly the same.
imackenz
Hey - don't know if this helps but I had the exact same problem with my 09D3 - turns out it was a damaged wiring loom (thats another story) I know mine is a D3 and yours a D2 but in your case perhaps just a bad connection / dirty connector somewhere in the loom from the sensor back to the computer.
just a thought...
GregDisco2
Alabama
Damage is possible. However, when I turn the car over and I have my scanner hooked up, it sees rotation of about 200 rpm. I think that means it is seeing the sensor signal. I was wondering about the coil but wouldn’t think both coils would just die at same time.
wrldky
Greg,
Not saying that this is your issue but I had the exact same problem. Replaced crank sensor twice. Turned out that I had a fuel pump issue. The pump was only a year old so I never suspected it and they make the damn schrader valve so damn hard to get to to check fuel pressure. Anyway that was my issue. New fuel pump solved it.
GregDisco2
Alabama
Thanks. I don’t have time to do anything until the weekend but that was my next step. Funny thing is when I pulled the plugs, they have fuel on them. I was going to check for water in tank, no obstructions in air flow or the exhaust and check fuel rail pressure. I’m really confused since I have spark, fuel(I tried to check with starter fluid) , and compression. I assumed it doesn’t have a choice but to at least hit a couple of times, but nothing. So I’m going to pull the plugs and blow them off, try to dry out the combustion chamber and try the starter fluid again in case I have moisture in lines or tank.
Bm7b5
Berkley, MA
This was happening to my LR3. I found this YouTube video:
And it worked. I told a friend what I found and he said it was the Cam Shaft Position sensor. I told the “Rover specialist”, who changed out my fuel pump and filter trying to fix the problem, about my finding and he literally laughed at me. I brought it to a local garage and told him what to do. He used an aftermarket sensor and the truck would start, but stall out (wasn’t stalling before). I brought it to the stealership and told them what to do- Done. 40 dollar part gave a ton of headaches.
- also no engine light ever came on and no non-engine light producing issues were picked-up by a scanner either.
Green Achers
Central Valley - California
I had my tach go dead a few months back, although the Engine still ran. My alternator wire (the small one) was not making contact. Replaced the end connector and not had a problem since. Not sure if that could lead to a no-fire, but it’s a quick check/repair and could resolve your dead tachometer.
PanKyiv
