No blinker sound
Awodarula
USA
No sound on hazard and blinker (turn signal)…but it works outside the car…2016 lwb Range Rover…
has anyone had this problem before? Any fixes without going to dealership?
bbyer
Alberta
Attached is a series of links to articles related to the replacement of the "speaker" located within the Instrument Cluster.
If you can do the labour, it is a cheap fix and even if you have to pay people to get the instrument cluster out, the fix is still cheaper than buying a new instrument cluster. A junk yard cluster will not work as the cluster has to have the software data from the old cluster transferred to the replacement as there is a chip mounted on the instrument cluster that is a backup memory for the engine computer chip located on the glovebox located fuse panel pcb - serial numbers have to match etc.
This is a speaker that worked from Amazon. The link has nice pictures of the speaker.
http://www.amazon.com/gp/product/B0...oh_aui_detailpage_o03_s00&tag=viglink21385-20
CES 2" ROUND REPLACEMENT SPEAKER 2 WATT @ 56 OHMS PAPER CONE TREATED CLOTH EDGE
2" SPEAKER
2 WATT @ 60 OHMS
PAPER CONE ACCORDION EDGE
1 OZ MAGNET
TREATED CLOTH EDGE
Below is a good link and says the speaker is 100 ohm.
Links to dash removal as well as speaker etc.
http://www.disco3.co.uk/forum/topic84798.html
Link to pdf re removal of speaker from PCB.
http://www.disco3.co.uk/gallery/albums/userpics/12690/D3_Speaker.pdf
More "how to" for the nitty gritty part of changing the speaker.
http://www.disco3.co.uk/gallery/albums/use...peaker.pdf
Some of the above links have good pictures and others relate specifically to Range Rover rather than Land Rover, but the speaker change is all the same.
GOOP
Memphis, TN
I'd love to have that problem. I hate the blinker noise!
bbyer
Alberta
Just be patient and you will not have the headlight warning, the key in ignition binging and a few other sounds - they all emanate from that same speaker.
You should still have the backup alarm however as that was a separate speaker located in the rear on the LR3 and might also be on the 4 but probably all in one for the newer vehicles such as the RR Sport.
helge
