O2 Sensors
cyberegg
I've already checked previous posts for info on replacing O2 sensors, but thought I'd ask anyway:
Any suggestions for sources to purchase O2 sensors?
Any suggestions or hints for installing them? (I think they are somewhere on the exhaust system)
Thanks
www.discountroverparts.com Nathan will take care of you.
'96 will have 4 of them.... back two are very easy to see, just crawl under then Disco and you will see them just behind the Cats.
The front two can be a pain in the A** the connectors are on the back of the engine and are not funnest to get to or change.
The connector types are the same, so I recommend changing the rear ones first, unplug them first by looking, then learn to do it one handed with your eyes closed.... then the top ones will be easy.
cyberegg
Joey- The link is dead. Do you know if they changed their name or ????
Thanks
cyberegg
Also, what about getting O2 sensors from an auto recycler?
I know generally getting electrical parts or brake parts is questionable....
Moose
Try www.discountbritishparts.com -- it's the same people.
There are ways to splice in 4-wire O2 sensors, although I think that's had mixed results...was that you, Joey, that tried doing that?
Can you change just the fronts, or just the rears, so it's not such a wallop on the pocketbook?
Basically the front are the ones that provide info to the ECU.... although the rears do provide info, they just say yes cat is working, or no cat is not working....
I didn't try to splice them, but you will have issues if you do any water crossings or if you don't solder (sp) or heat shrink them very well.
And yes moose I miss typed the url to Nathans site, sorry.
Hae79547
