Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have a 2007 LR3 and was wondering about changing the oil at the local valvoline drive up? Is there any reason this can not be done? No lifts ( air suspension) just drive up remove filter and change the oil.
Shouldn't be a problem. Two skid plates to remove with lots of bolts, make sure they are all put back. Also good idea to replace the plug seal washer. Doubtful they would have that though. I change mine myself, fairly straight forward.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
