oil leak
dragan
My 05 LR3 have leak. It turns out to be an oil leak from "somewhere towards the front of the engine" leak coming from above cylinder head (left side)I assume, is hard to see Anyone have info on this?
davez26
Camshaft cover Gasket
The only oil-bearing item above the head is the camshaft cover gasket. So that's a possibility. We do those from time to time. Other than that, ther'es not much more to pick at from the description. This is the same design cam cover Jaguar has used for years, and we do a fair amount of those. I'm surprised we don't do more of them due to oil leaking past the orings around the plugs causing a misfire, but I'm sure that is coming.
As these vehicles age, I'm sure I'll hear more and more, can I do it myself? I think if you have a fair amount of mechanical knowledge and you had the pertinent torque info from GTR, most people could do it.
I should probably not answer this stuff before I finish the first cup of coffee.
The newer generation of vehicles has been pretty interesting...
dragan
Thanks four quick respound
my car is in shop last 6 month.
Lr dealer tray to fix leak by replacing PS pump.
Monday I found oil coming from above AC comp (camshaft cover).
Oil dripping on AC comp, from there to PS pump.
What need to be removed to fix gasket on 4.4 V8.
Thanks
