Overheating-need help now
T
tkraus
Hi,
I got to work this morning and there was steam coming from the hood.
The temp gage never told me it was hot. I did smell radiator something. I
looked under the vehicle and there was a dripping toward the driver
side front. I am about to have a garage come look at it. Any ideas? I am
90 miles from my house and by myself. It has 103000 miles on it. The
water pump was replaced at 50000 by the dealer. It had a crack in it.
Help!
Trecy Kraus
Columbus Georgia
D
disco1
Did you see exactly where the steam was coming from? It could be a burst radiator hose. Personally, I have never trusted the water temperature gauge, and fitted onto the expansion tank, a low water level sensor from an early model Range Rover, wired to a 'piezo' buzzer which I located under the dash. Now, if the water level drops a inch or so, the piezo is activated. Sure beats a potential blown motor.
Check to make sure the expansion tank hasn't burst... common on the black tanks.
T
tkraus
thanks for replying! The steam was coming out of the driver's side of the vehicle. The garage just picked it up. I had no fluid. Surprise, surprise. He told me the dripping underneath the vehicle was not supposed to be there. That it could be a hose. My husband is deployed so I definitely appreciate ANY help I can get. I know this sounds totally dumb, but shouldn't the temp gage have risen when I drove in? I had no warning lights or anything.
Yes the gauge should have gone up, but unfortunatly it does not always read or show the correct temp. I would recommend a good external temp guage.... but then again... I need to do this to soon.
T
tkraus
Overheating followup
The mechanic said they can't get it to overheat now. So we shall see. Does fluid get used up or evaporated when it is hot? I know this sounds dumb. He also said my hoses are getting worn. What kind should I buy? I DO NOT go to the dealer unless I have to. Thanks again
62Sunbeam
My Disco overheating problems were similar until I added water wetter to a much diluted coolant. I would imagine that the engine got hot enough to blow by a loose clamp or something.
I wouldn't run the A/C till you get to the bottom of the problem.
Good luck
Eric
95 Disco
I prefer Makers Mark :)
**** Eric ****
If you had to add water wetter, it may be time to have your radiator rodded out or replaced.
tragic1
