P0328 Knock Sensor
Pfunk951
Team,
So, after 121k miles, I've finally got a CEL. Bank 1 knock sensor high input. This one is turning out to be a mystery as the standard fixes aren't working:
1. I've replaced both sensors
2. The wiring looked OK when I was in there.
3. Light went out for a week, and came back.
Some notes on this:
1. I've reset the codes multiple times, it keeps coming back
2. Many tanks of good, high octane fuel (93), from multiple places
3. Motor mounts seem good, I've loaded the drivetrain with my foot on the brake and the engine barely moves
4. I can drive on the highway for hours and the light won't come on. Including 5k+RPM revs pulling a trailer up hills, so the engine is getting pushed/cycled.
5. It only happens in town.
6. Performance is affected, but not much..
7. 5.0 V8, 2012
Any thoughts on this? I've checked out the Jag forums, and am not finding a ton of useful information..
Thanks for the help,
Mike
powershift
Nevada
Get a data logger and record the KR PID. That will show when its getting knock vs watching for the CEL. See if you can narrow it down.
Pfunk951
Good feedback, thanks guys.. I'll start checking that circuit, pretty sure my OBD reader can check that real time. I'll let you know what I find..
Mike
Pfunk951
Closing this one out for posterity- it was a High Pressure Fuel Pump..! These are on the same side of the engine as Bank 1, and must have got loud enough to trip the sensor. The pump failed at an Overlanding Rally- I limped it home. I replaced the pumps and the code cleared, and a couple of hundred miles and all is quiet on the dash.
MP
Pfunk951
There you are! This was at Big Iron- absolutely amazing time.. The pump shot craps somewhere in North Oklahoma, made it back to the festival in Kansas and drove back to KCMO the next day.. These things can be finicky, but driving 400 miles with a pump out is a testament to not getting stranded!!
I've got a write-up in the works for the HPFPs..
Mp
