P38 1998 Fuel Pump
SierraRover
1998 Range Rover Fuel Pump Replacement
If you have a 98 Range Rover, it uses a STC 4345 fuel pump which apparently has been discontinued and applies only to 1998 Range Rovers. The fuel pumps are expensive and hard to come by now. The 1995-1997 Range Rover uses an STC 4344 fuel pump still available.
BJ, the answer is yes, they will just about work with any Rover cause you are only replacing the pump, not the entire pump housing.
