Jimmy Brooks
Sorry for no feedback, Jimmy. Been out of town. I know I've checked my mafs using the tool, but I don't recall what the fields were anymore - maybe just airflow, which is fine if you can compare the two sides to see if they are about the same. Unusual that both would go bad at once, though both could be dirty if you've been offloading, driving around the forest fire smoke, etc.
Can't remember what else has been covered already. O2 sensors, purge valve, fuel pressure regulator (fuel rail)?
Sorry, just trying to move on this issue, seems to be getting worse daily. I tested the purge valve and it is closed when the car is off. Fuel pressure seemed normal, is there any specific PSI I should be looking for? When I was doing harder pulls it ranged from 2650-2800 psi.
Is there any specific live value I should be pulling up for the O2 sensors? I had bank 2 O2 sensor 3 (furthest one back in drivers side) go bad. Replaced it and the CEL went away. Problem remained and behavior never changed.
On a side note I noticed that when I smoked tested the intake there was no smoke making its way into the crank case, when I opened the oil cap there was no smoke coming out. Not sure if that is normal for these cars.
Haven’t been off-roading in a long time in this car, I can check the air filters and try to clean them. I purchased the sensors just to try to rule it out.
What are the symptoms of a bad low pressure, thinking it could be a part of the issue but it’s hard to say.
