Radiator leak
ElChuco
El Paso
Changing my radiator as we speak. 220k on the old one. It all started with the bleeder valve hose ****** breaking off under the intake manifold, needed a new thermostat housing too ($139.00), then grabbing the hoses one by one the radiator ****** (plastic) came off at which part I decided to replace the radiator, while disassembling , I noticed the upper hose inlet being soft and totally disintegrate when I squeezed little harder. I'll pull it out and will take pictures of the rest of the inlets just to see if they've all gone soft. JLR OEM radiator goes for over 600, parts dude would have given it to me around 500 after taxes, in the end he ordered me an aftermarket one they use themselves, cost me around 350.00... ,no contest, buy a new one either online for little less +shipping, or for few bucks more talk to your local Landy shop and get a "local" 4 year warranty with your purchase. By the end of the day, I'll probably have to shell out another 500 for all the hoses, hope not.
Thanks. I have not tested my JLR guys here by asking them for non-OEM workarounds. Maybe this would be a good moment to test their bona fides with that question.
ElChuco
El Paso
Mine had leak, UV dye you could see it leaking. Tried K seal turns orange radiator fluid to green fluid. Worked for 2 days then totally threw a clot. Wouldnt waste your time. I bought new radiator off rmEuropean. Cheaper and seems just as good as oem. Pain to remove and change but totally doable.
Good advice. Thank you.
