Radio Problem
omega0407
already I look the outboard amp under the driver seat and the fuses are ok.
what else can I do?
I wan to let you know than before this happening the little red light ( antiT) the one is in front of the redio was on. now is off all the time.
Is there anything do I can do?
98GRDisco
Check the speaker harness on the back of the radio it may of become disconnected or if thats ok check the harness for any breaks
omega0407
I did it already I take the unit out, disconnected it in and out, I turn the radio on, I move the harness and no sound. the unit is on but still no sound ??????????????
Does it ask for a code when you do turn it on? if it doesn't I would say the radio is bad.
JSabah
HI!
GUYS!
I HAVE A LITTLE PROBLEM WITH MY RADIO, WHEN I TURNING ON I CAN SEE THE RADIO ON BUT I CAN'T LISTEN ANYTHING.
CUOLD ANYONE HELP ME WITH THIS PROBLEM
THNK YOU!:albertein
Did you ever find a solution to this...I have the same problem - radio or CD on you can see the station on track, but no volume and no volume indication...it seems to have happened after a car battery change. Please let me know if you found a solution. Thanks, Josh
SulliMtn
