Radio - service menu
steini
Hi hi
I have a little problem related to my radio, my radio frequency is only showing odd numbers, that is 90.3, 90.5, 90.7 and so on, how can i change this so i can also have 90.4. 90.6 and so on??
best regards
angasreid
hold the right knob down, that should take you to another menu. You'll see the country etc, shouldn't be too difficult. You may loose your presets though.
steini
hi hi
thanks for quick reply
I have tested this, changed the country and got the right radio frequency but when i turn off the car the settings go back to the same when i start the car again, do you know how i save these settings?
best regards
Steini
angasreid
I can't recall off hand here, but it sounds like you're not making the radio "save" the new settings. Try turning the radio off with the power button, or something like that. I'm not with my car right now, but I think that's the issue.
angas, I could never save those settings on the radio's service menu beyond an ignition recycle (was trying it on behalf of someone who moved abroad from the US with his LR), everything would default back to stock. I therefore assumed that only a dealer could get them to "stick", via diagnostics. If you find out otherwise, please let us know.
steini
yebb, exactly my problem too and cant seem to get these settings to save, would be great if someone could post the solution for this :proud:
angasreid
I'm currently out of town here, but when I get back I'll see what I can do. Until then, Happy Thanksgiving.
