Radius Arm Question
bakjar
Hello,
Replacing bushings on panhard rod. should be an easy job.....remove two bolts to remove panhard rod. Though one bolt cant be removed without removing the radius arm at axle:mad:T Fine...two more bolts....the front one came out easy.....I cannot get the other out for the life of me.
I know someones struggled with this before...any suggestions on how to relieve pressure on the bolt so I can push it out? Ive tried levers, clamps, hammers, wd40....
Thanks in advance.
