Rear AC blowing warm
traviswright
I have an '05 LR3 HSE, and the rear air started blowing warm yesterday. The center console still blows cold, and I have checked the dash and rear control panels to ensure they are set properly. Does anyone know if there is a seperate refirgerant charge for the overhead and cargo compartment AC? Any other thoughts on what might cause the air to blow warm? Front AC still works great.
Randall
If yours is a seven passenger with the rear climate control package i would think that added additional hardware that would be separate from the front but i don't know for sure
kingfishgrapeja
If you haven't found it already the guts for the rear are located in the left rear stowage compartment. Dunno if there is a fill valve back there
Mony210
Fontana
Hello, I am having the same issue, warm air only on rear. I have 7 seater. Is there a fill valve at the back?
douglastic
Valves are only up front, just like 5 seater - No rear valves
Only difference is the volume of refrigerant
Sticker above grille says how much for each (front only vs front/rear) system
