Replace alarm ecu?
callmehero
Hi All,
I purchased this 97 Disco 1 SE7 without proper keys or a fob. I have since replaced the lockset with a salvage set that came with several original keys. I have the alarm ECU and fob from the salvage vehicle but am having difficulty swapping it out. Is there a procedure for this? I haven't been able to find anything online that helps out. I tried doing a direct swap and the alarm and immobilizer activates - and I am unable to deactivate it using the unlock four times procedure. I've tried the procedure referenced at http://en.allexperts.com/q/Land-Rover-Repair-1470/Alarm-Remote.htm but cannot seem to get it to work. Do I just keep trying?
Any suggestions would be helpful,
Anna
Sadly if you replace the alarm ECU you will need to have the system programed for it. This will require a LR Dealer or someone with the correct LR computer to plug in and talk to the ECU.
You should be able to use any of the rover Fobs for a D1 with the ECU, it just needs to be programed by the dealer or similar with ROVACOM computer
callmehero
Sounds like it'll have to wait, nearest dealership is 2.5 hours away and I need to do my brakes before I go that far.
Thanks for your suggestions!
Paul p
