Resetting service required message
namenda
I saw this on the RRS forum. Does anyone know if it works on the LR4? If it does, I could have saved myself a $200 SIR dongle.
1) Turn on ignition (foot off brake)
2) Open Hood
3) Open Driver door
4) hold brake & gas for 20-30 seconds
5) Let off brake gas
6) Turn off ignition.
Pfunk951
I'll try it right now..
Mine's on too..
Edit:
No Joy. I tried it twice and couldn't get it to work..
I'm hoping for a solution, I have the same message and feel dumb going to the dealer to have it shut off..!
Pfunk951
Wait.. I just read that this works only on the MY2014+ models, I'm a 2012..
Is there anybody out there with a 2014+ that can try this? No benefit to me, but good info for posterity..
Mike
HOW TO RESET OIL CHANGE SERVICE LIGHT ON 2014-2015 LAND ROVER LR4:
To turn off the Oil Service Light on Land Rover LR4, conform to the following instructions:
  • Turn the ignition on
  • Open the hood
  • Open the drivers door
  • Turn the ignition key to position II, If your car has push-button start, press and hold the ” Start” for two seconds without touching the brake pedal.
  • Next, simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 10 seconds, until a “SERVICE RESETTING.” message shows on the instrument cluster display.
  • Turn the ignition off and back on
  • If the message is not cleared, repeat the process
Haleakala
This procedure:
2) Pop the Hood
3) Open Driver door
4) hold brake & gas pedals for 20-30 seconds
5) Let off brake & gas pedals
worked after the first oil change on my 2016 LR4.
It does not give you any indication that it worked other than the service light no longer appears when you start the vehicle.
Ryan00TJ
This procedure:
2) Pop the Hood
3) Open Driver door
Exactly, did the same to mine after the JLR techs forgot to reset it after the first annual service.
gsxr
Big Sky Country
Is there any procedure that works for a 2010-2013 LR4? I have not been able to find anything at all.
Reset is done with a diagnostics tool for those model years (dealer or aftermarket tools such as IIDTool can do it.) Only 2014s and later can be reset without it.
Alexander
Inland Empire CA
I purchased the diagnostics tool from amazon for around $120 I believe. It was easy to reset with it and in my opinion it is worth it to have
DoornbosH
