tjp74
- Joined
- Jan 29, 2010
- Posts
- 147
- Reaction score
- 0
Is it possible to retro rear air conditioning on series 2 SE7? that is if I can get all the parts necessary for cheap?
My 2000 SE7 got everything even the ACE whether that's good or bad (but I like it so far) but it's got no rear AC dispite being a SE7 model. A rear AC would make this car "fully" loaded finally.
I see that I can buy used parts faily cheaply. The whole evaporator/fan assembly out of series II car can be had for less than $100. Air vents, controls, ducts and trim covers can be easily sourced for cheap. Not sure if wirings are all there but that could be little tricky if I have to wire them from scratch. Then there is the freon lines. I suppose it will be coming from the front HVAC unit or directly from the engine?
Is this possible????
Also, what parts are interchangeable between series I and II regarding the rear A/C? I see rear vents and controls look same. Are internal air ducts, freon pipes and wires same by any chance? There is a 97 with the rear ac in my local pick and pull yard.
