Rhino OX Hitch Torque Specs - Who knows them?
CoastieLR4
Cape Cod, MA
I bought a Rhino OX a while back used.. does anyone have the installation instructions they can share?
Mainly just need to know the torque specs for all the bolts! I can't find them anywhere online.
Thanks!
CoastieLR4
Cape Cod, MA
Thanks! I had already but didn't know if any of you knew it off the top of your head. All installed and ready to head to the mountain.
Annapolis, Maryland, USA
I found my instructions and will cut to the chase with the torque values first and then try to attach a scan of the Fitment Instructions for future reference in this thread.
Step 6:
First tighten the 40mm bolts to close the gaps
Tighten 75mm and 100mm bolts to fit
Tighten 40mm bolts to fit
Tighten the 75mm and 100mm bolts to 70Nm
Tighten the 40 mm bolts to 70Nm
Tighten the 30mm bolt on the hook plate to 70Nm
  • FITMENT INSTRUCTIONS.pdf
PE_in_UAE
