- Joined
- Jun 28, 2004
- Posts
- 10,495
- Reaction score
- 188
Hello everybody. In the last past weeks my 96 disco manual has been put out a lot of check engine light codes. And the last two days it’s been having a tough time starting. When I first start my disco it sometime doesn’t respond to my key turning to start the engine it’s like a die battery. But if I try it again you can hear it attempt to start. Then it does after the second or third try.
I don't think it’s my MASS AIR FLOW SENSOR because my idle is fine. But I do have an Air Force One Intake system. My coil pack looks good still I only have 97000 miles on my disco. I already did a major tuned up on it. With all new spark plug, magnacore 8.5mm. Replace all 4 o2 sensors. I also install some hedman headers. And did a custom dual exhaust system with straight cats. Car was running fine for the last 4 month until now. Please could something please save my disco.
1. air fuel meter , random missed fired
2. multiple cylinder missed fired
3. ignition system failed
