shopping for a 2 or 3 inch lift, see if this setup seems ok...
DiscoFever
From EE
All parts are OME
shocks--N107 for front and N108 for the rear
springs--751 for front and 781 for the rear
also the website states that to even out the rear I would need to install a 1" spring spacer
I have a few questions about all of this though:
1, Do I have to replace the shocks to acheive a lift?
2, What option do I have for the front springs so that I would not need to install spring spacers in the rear?
the website claims that the above setup will give me a 3" lift, but I am not set on a 3" lift and woulc be more than happy with 2", what setup would accomplish that
one last thing, total for all parts including rear spring spacers comes to $640 not including shipping, does this seem about right for a 3" lift?
I am open for any and all recomendations
thanks in advance
D
discomike
Here is another web site, where I bought my OME's, there is alot of info to help you. Yes will need to switch shocks for 2 reasons, a little extra length and your's are probably worn out any way and won't handle the stiffer springs. Make sure you replace the steering dampener also.
Do you have a aftermarket bumper and or winch, if so the 751's are a must, if you go lighter on the springs they will drop their height quickly.
I can send you a couple of pictures with the 3" lift if you want to see what it looks like.
Mike J.
DiscoFever
Thanks mike i would appreciate some pics, and what website were you referring to, i didnt see a link anywhere in your post.
DiscoFever
Email sent...
yeah expedition exchange, EE, is the site that I originally posted about
thanks
chris
D
discomike
Hope you got the pictures, sorry, I didn't pay attention to your first posting as to where you got your information. By the way, what size tirees are you going to be running?
Take care,
Mike J.
DiscoFever
the biggest tire I would ever run would probably be around 32, but initially when I lift it I would most likely just use the stock size tire.
D
discomike
265's are only 32.9 and they make such a hugh difference, with there stronger sidewalls.
Take care,
Mike
tmiller1
It sounds like you are going to have an excellent ride once lifted - but I would recommend following discomike's advice. I almost ripped a hole in my stock sidewall on Porcupine Rim in Moab last year. A thicker sidewall, and more height, would have made a world of difference on that trail for me.
Hae79547
