Should I go to the dealer for the alignment?
appletigger
I went to the dealer today for 30,000mi service. My LR3 had some other problems like, steering wheel peels off (just a bit), ceiling rattles and tires wear inside.
Dealer fixed the rattle problem and replaced the steering wheel, but the alignment was around $170 + tax (maybe + labor as well?). I'm about to replace my tires in 2 weeks, so I guess I'll get the alignment done after I put new tires. I think $170 is too much....
Have any of you got alignment other than dealer in Los Angeles area?
Is there any shop you guys would recommend?
Thanks in advance for all your help!!
drzjoint
from what i understand you want the dealer to do the alignment. what tires are you getting?
m5ccie
Dealer is the only option for alignments. They are the only ones that that have the equipment to set the suspension to a lock mode in order to align the vehicle properly. I paid $150 for mine a few weeks ago.
toddjb122
...that would suck if this is true.
When I first got the truck one non-dealer shop said they couldn't do it. But, a few months later specific truck updates seem to have made it out to the alignment computers and now places say then can do it. But yeah, if the truck suspension has to be locked to do it correctly....
richpike
I've heard that many dealers outsource this (and mark up the cost). I've had it done at both an independent shop, and at the dealer. Both seemed to do fine (although I had to take it back to the indy shop to one additional time because it wasn't quite right - steering wheel angle was off). This last time, I just went to my dealer and had it done - cost ~$90, and I knew it was done right. Sounds quite a bit cheaper than what you other guys are seeing, but I have a fantastic dealer, so maybe that is why.
-Rich
m5ccie
From a post from MustBeAudi in this forum:
Uneven tire wear.
The steering alignment geometry of certain vehicles may experience some bushing settlement during early vehicle life. Following initial production geometry setting, this settling may alter the geometry settings outside of normal tolerance, which may in turn increase tire wear.
Revised geometry settings introduced after 6A403382 compensate for this situation.
NOTE: This situation is not experienced on all vehicles. Toe sensitivity may be attributed to other factors.
CAUTION: Retailers who sublet alignment to outside shops must provide the information in this bulletin to the alignment facility to ensure proper settings when uneven tire wear symptoms are being addressed. Additionally all vehicles equipped with EAS sent for sublet alignment MUST have been placed in the “tight tolerance” geometry setting mode prior to delivery using IDS.
Action: Should a customer express a specific concern of uneven tire wear, refer to the Repair Procedure detailed in this bulletin to adjust the vehicle geometry to the “target” settings noted below. NOTE: In other situations requiring geometry adjustment, where a specific concern of uneven tire wear is not expressed or diagnosed, the geometry dimensions in the workshop manual should be used. A specific set of “target” geometry data is provided in this bulletin for use in vehicles where the geometry needs to be adjusted to correct an uneven tire wear concern.
PARTS:
No parts required
WARRANTY:
NOTE: Repair procedures are under constant review, and therefore times are subject to change; those quoted here must be taken as guidance only. Always refer to DDW to obtain the latest repair time.
NOTE: The revision to the time in this bulletin is the result of the introduction of the new IDS “tight tolerance” geometry setting mode for suspension adjustments. This simple IDS process replaces and eliminates the requirement to perform a suspension calibration (1.1 hrs) in association with the alignment process. Refer to Technical Bulletin LA204-007 for additional information about the geometry setting mode. DDW requires the use of causal part numbers.
Labor only claims must show the causal part number with a quantity of zero.
Description SRO Time
(Hours)
Condition
Code Causal Part
Place vehicle in “tight tolerance”
mode using IDS and align suspension
geometry
57.65.04 1.80 W6 ALGN4W
Normal warranty policy and procedures apply.
REPAIR PROCEDURE
ALIGN SUSPENSION GEOMETRY
1. If the vehicle has Electronic Air Suspension (EAS), refer to Technical Bulletin LA204-007, connect IDS to the vehicle and place the Electronic Air Suspension (EAS), into “tight tolerance” geometry setting mode.
NOTE: A small number of coil sprung vehicles were imported into North America at the very start of LR3 importation. Step 2 is included in the event that such a vehicle requires suspension alignment.
2. If the vehicle has coil spring suspension, perform the following steps to ensure that the equivalent of a full tank of gasoline weight is present in the vehicle when the alignment process is performed:
NOTE: LR3 fuel tank capacity is 22.7 US gallons (86.3 litres). A full LR3 fuel tank weighs approximately 152 lbs (69 kg).
• Accurately determine the volume of fuel in the tank.
• If the tank is not full, calculate the weight of the fuel in the tank using one of the following formulas:
o Multiply the number of US gallons of fuel by 6.7 to equal total pounds of fuel.
o Multiply the number of liters of fuel by 0.8 to equal total kg of fuel.
NOTE: Any weight equivalent placed into the load space area must be evenly distributed at the front and the right hand side of the load space.
• Calculate the weight equivalent that must be added to the load space area by subtracting the total amount of fuel currently in the tank from the LR3 fuel tank capacity of 152 lbs. (69 kg).
NOTE: Vehicles that have any of the front or rear, upper or lower control arm bushings changed must complete a ten mile road test before having the geometry checked and adjusted if necessary.
The road test will allow the suspension to settle.
NOTE: GTR lookup sequence is as follows:
GTR Home > NAS > Service Information/ LA – LR3 > Workshop Manuals > Bookmark “Chassis/Suspension/204-00: Suspension System – General Information” Link “Four-Wheel Alignment (57.65.04)”
CAUTION: GTR identifies an alignment specification range.
The exact “TARGET SPECIFICATIONS” in the table below should be used on vehicles that have experienced uneven tire wear.
When setting suspension geometry after front or rear/upper or lower control arm bushing replacement, the rear toe should be set to the TARGET SPECIFICATION in the table.
3. Refer to GTR section 204-00 Four-Wheel Alignment operation 57.65.04 and adjust the front and rear wheel alignment to the “TARGET” specification figures noted in the table below:
TOE ADJUSTMENT
TARGET
SPECIFICATIONS
(decimal degrees)
Front total toe + 0.03
Left-hand rear toe + 0.18
Right-hand rear toe + 0.18
Rear total toe + 0.36
