Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
My daughter in law drove my 1995 Disco to a hamburher joint and when she got back in the car it would not get out of park. I had to go and get her. So, no Disco,.....and no hamburger!!! Help anyone
Brake switch is probably bad... down by the brake pedal you will find the switch, you can put a jumper it for temp use, but brake lights will always be on. You can also disassembly the center console and remove the shift lock.
You will need to replace the brake switch either way.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
