Switching to LEDs for headlights 2010 lr4
gsxr
Big Sky Country
Why did you switch from HID to LED? What's the candlepower difference?
I assumed Louis meant halogen to LED. I've never heard of any HID to LED conversions, and the candlepower/lumens difference should not be significant. I'm also not sure if LED would work properly in an HID projector. Google implies it's generally not a good idea:
Can I replace my HID headlights with LED?
Yes, but it is not recommended unless you change your entire headlight assembly. HID bulbs are almost always in projector-style headlights for which LEDs do not perform well and can be very dim.
That, and HID bulbs have huge candlepower ratings. Not sure any of the LED bulbs have reliably gotten that high, yet.
Louis Heinz
Miami, FL 33129
Yes gsxr is correct. I do mean halogen to led. The lr4 I have is the base unit although it does have the 3rd row and ac controls for the rear. I changed the low beams to led because it does provide much more clarity.
Side note: I was able to buy a hse navigation display, cd unit and radio from a salvage unit. It was tested in front of me so I know it works. I disassembled the entire dash thinking it might be just plug and play. boy was I wrong. Does anyone know how I could make it work . The salvage is exactly the same lr4 year except it’s hse vs mine being base(se)
defiant
Alberta, Canada
OSRAM Xenarc Cool Blue Boost D3S... https://www.amazon.ca/dp/B0771LK8B1?ref=ppx_pop_mob_ap_share
These guys work great.
Louis Heinz
Miami, FL 33129
I also got my halo to work by putting a led strip in the area.
