Tech stud info
Zakman
Does any one know what stud size is on the 2010 Land Rover Sport SE....1.50mm or 1.25mm thread pitch??? And.....What is the length of the stud from the mounting surface?
Welcome to the forum... Tech question are best asked in the Tech Section... LR Sport? as in Range Rover Sport? if so I would suggest asking in the Range Rover section or even over at www.rangerovers.net
Zakman
Sorry about that. We're installing a set of aftermarket wheels on a 2010 LR3 Sport Supercharged and found no one had taken care of lug nuts. As it turns out, we were able to verify that the stud thread is still a 14 X 1.5 and while we didn't find the actual measurement, the studs are a little short for just regular acorn nuts. It turns out there are a couple companies that manufacture a special nut with a shoulder that protrudes into the thru-hole to gain 4-5 threads. Mods, feel free to move this where it will do the most good. Thanks for the reply!
MrRodgers
