Thinking of a Disco!
R
RoverMan75
I need an SUV(1st baby on the way!)I realy like vintage Rover's,among other old auto's.These Disco's seem to sell pretty cheap for there age(8-10 yr old models)Just wondering what the rundown on them is????Quality,reliability,parts cost......???????It will see mild off roading and pleanty of winter driving.Any help is greatful.
R
RoverMan75
I forgot to add,i'm VERY good on maintance and not abusive on my cars and trucks.
Moose
Look around here a bit and you'll see a lot of opinions.
I have a 1996. I've owned it since 2001. It came to me with 54,000 miles and now has 114,000. In that time I have:
  • Replaced all brakes
  • Re-replaced front pads
  • Replaced stock tires with AT tires
  • Replaced AT tires with MT tires in a larger size
  • Replaced shocks and springs with longer versions
  • Replaced fuel pump twice
  • Replaced plugs
  • Replaced plug wires (Magnecor)
  • Replaced front passenger door
  • Replaced front driver's window regulator and motor
  • Replaced alternator
  • Replaced water pump twice
  • Replaced battery
  • Replaced old rusty exhaust (cat-back) with now-rusty exhaust (cat-back)
  • Replaced inertia switch
  • Replaced Vehicle Speed Sensor
  • Replaced brake light switch
  • Replaced oil pan gasket
  • Cleaned 3/4" of sludge out of oil pan
  • Replaced serpentine belt
  • Resoldered the rear window lift ECU
  • Removed the ~54K emissions reminder
And changed the oil dozens of times, the tranny fluid, the diff fluid, and the headlight fluid :biggrin: . They are relatively easy to work on, and extremely quirky when it comes to electronics. If you get one with maintenance records of any kind, you're better off. Regardless, you should swap out all fluids when you get it, and the truck will love you for every thing you do on time. They are beasts, safe in collisions, and will almost certainly get you where you're going.
Parts are easy to find via the internet for less than a dealer charges, and most engine components are bolt-on (I did the alternator in about 15 minutes, and the fuel pump is quick too). The "Classic" Discos are more directly descended from the Series, Range Rover and Defender trucks of the 50s-80s, so they are eminently more field-repairable than other makes or more recent Rovers.
Long post, but I hope this helps. Patience and a willingness to learn the truck are requirements for happy ownership, IMO...
F
fbrems
Hey RoverMan
I'm driving my third Disco from new (1998) and it seems that the defects are common if you go over the referendum of owners.
Summarizing the breakdowns before 100.000km (other than normal maintenance)
> Replaced Water Pump
> Replaced Belt Tension Unit
> Overhauled Stearing Pump
> Replaced Steering Rods
> Replaced all Sparkplug Cables
> Replaced Distributor
> Body repainting (top back windows and doors)
> Replaced Window Motor (2)
> Replaced Fuel Pump
> Left Mirror Motor
> Interiors get loose everywhere (roof came down)
> Replaced L & R exhaust manifolds
Summarizing the breakdowns after 100.000km (Currently 120.000km)
> Replaced Fuel Pump
> Repair Gearbox (did not shift)
> Fuel Tank is Leaking (crack on top)
> Window Mechanism failure (frames in door got stock)
> Got condension in the head lights (mirror is fading away)
> Start to have Steering Vibratrions
> Steering Pump Leaking
> Front Crankshaft Bearing Leaking
As you mentioned, you are very good at maintenace issues, than do not worry to much, the Disco is not a difficult truck to work on. I find Rover parts expensive, but that is probably different in your place of living. Do not underestimate the fuel consumption. My V8 (3.9) love's fuel as the Irish beer.
Average consumption > 15l/100km to 20l/100km (city) Off Road > 25l/100km luckily fuel is inexpesive in UAE but I will not be able to afford such engine back in Europe.
Hae79547
