Throttle Body Heater Plate Kit
bolha79
Throttle Body Heater Plate REPLACEMENT
On A 04 Disco Location, And Hard To Do? Do I Need To Remove Anything?
Easy to replace, just make sure you get the newer rubber gasket or it will leak again soon.
Takes about an hour or so. On a scale of 1 - 10 with 10 being hardest about a 2 or 3.
Remove air intake hose, remove the water lines to the heater plate, remove the butterfly (easy way), then remove the the heater plate... replace the gasket then reverse.
PE_in_UAE
