Towing Question- RRS
tlgolden
First off- Thanks to all on the forum. I've learned a ton reading these posts over the last few weeks. I have a 2007 Range Rover Sport and will be towing an ultralite travel trailer (dry wt- 3800lbs) with emergency brakes but no surge type brakes. Driving in Florida so no hills. Maybe 3-4 trips per year of no more than 200 miles each way max.
The manual says not to use a weight distributing hitch. I have a Reese Heavy Duty Weight Distribution System. See here: http://www.etrailer.com/tv-weight_distribution_and_sway_control_install_ford_van.aspx
So what do you all think. This system is supposed to cut down on sway. Should I use this weight distribution system or not?
Thanks in advance for your input.
Terry
You will hear mixed responses to this, but my opinion is that you should use it and you will be safer for it. I would also use sway control with it. (that is if you have already purchased this)
etrailer
Terry
If the owner manual for your Land Rover says not to use a weight distribution system then don't. It means the vehicle frame, the factory hitch or both cannot handle the stress that a weight distribution system must exert to function. Not following the owner manual can result in the manufacturer or dealer not honoring warranty claims.
If sway is a problem, there are sway control solutions available that do not require the use of a weight distribution system. They are friction based systems, not like the dual cam that I assume you have with your weight distribution system. This way, you have the added safety and driving comfort of a sway control system on the trailer, and still follow the owner manual.
STQAddie91
