Towing with 2017 Discovery
Nadine T
North Carolina
So I can finally share some experience after a few trips with the 2019 Discovery and the Flying cloud 19 Airstream:
After having towed with and without the Blue Ox Sway Pro bars installed, I can say that at least to my feeling, the car tows better without it. Much smother ride, no sway and natural fell. This weekend was really windy and other trailers were suffering down the highway, but we could go 60 mph with no sway. The only thing is that the ball moves more inside the couplers and you fell it when pulling out or braking.
I am sure this combination can pull a much bigger trailer, as a matter of fact you have to be careful when pulling the 19 because it is easy to go over 70, you don't even notice the trailer behind sometimes. Anyhow, we are afraid that in the disgraceful event of an accident being over the factory limits can become a liability issue, and that is something to be consider. We have been towing over the limits with our Flex for 3 years, so no pointing fingers at all on my comment, just thought for those considering it as we did.
We have a 23 on order and we are not going to use the weight distribution hitch, but we might consider some kind of simple anti sway for additional safety.
Gallego,
We are in a similar position to what you initially posted - we own a 2020 Discovery & want to purchase a 2021 Airstream 25 Flying Cloud. We currently have a 22 Airstream Sport that we towed with an Explorer. With the new car we want to do bigger. Just curious what made you go with the 23 vs 25ft?
Roaring Fork Valley, Colorado
Turned in my 2017 D5, and just got a 2020. We have a 20ft Ged Pro (4000lbs TW #560) which I also pull it with a Tundra. I agree with Gallego, while I need the WDH (Anderson with anti-sway) with the Tundra, the D5 not only doesn't recommend it, but it is just not necessary. I am at about 50% of capacity with both vehicles and couldn't be happier with the way the D5 pulls. I live in central Colorado, so theres no such thin as flat on our trips.
ar077
Las Vegas, NV
As for 7mpg towing a trailer, another deal breaker. Our 2011 LR4 with the 5.0V8 routinely runs at 16-17 mpg towing a travel trailer at altitude. Feels like the drive to optimize CAFE fuel efficiency has left no margin for activities like towing which is not part of CAFE. Another deal breaker. That list is getting really long.
Didn't see any posts by D5 Td6 owners. For those planning on towing large trailers, why would a diesel not be your engine of choice?
Dario Atallah
Louisville, CO
I just bought a 2017 Discovery HSE Td6 to tow a Lance 1995 (which I have not received yet). My only concern is if the tongue weight happens to be 15% of the trailer weight, as opposed to 10% - 14%. At that tongue weight the Discovery will see more than the rated hitch rating.
The diesel engine is the same engine used on the diesel F-150, which can tow a lot more than the Discovery, but it would not fit in my garage and is really longer than I want for every day driving.
Pb83925
Austin, TX
Hi All. I have a 2018 Discovery Td6 with the optional class IV tow hitch which is rated to tow 7700 lbs and thought I would share my experience in case it is helpful to someone. For about a year I towed an Airstream Nest travel trailer over thousands of miles through all kinds of road and weather conditions and for that 4000lb trailer the D5 was the prefect tow vehicle. I did not use any sway control or weight distribution and was able to tow at speeds up to 75mph safely and comfortably. Plus, when I arrived at a destination I had all the off-road capabilities of the Discovery to get me to trailheads anywhere I wanted to go. It was really a great setup.
About a year ago we traded the Nest for a 2020 Globetrotter 23FB which is about 6000 lbs. Those extra 2000 lbs completely changed the dynamics of towing. This setup absolutely requires sway control. I towed the Globetrotter for short distances with out, and that is not a good experience at any speed above 50 mph. I really wanted to use a weight distribution hitch with integrated sway control, but after doing a lot of research and speaking with a couple guys at Caman RV I decided to go with Land Rover’s recommendation to not use weight distribution. If you look up a drawing of the D5 trailer hitch (https://www.landroverpartscounter.com/oem-parts/land-rover-kit-tow-bracke-lr083050) it is more or less a straight bar without the long extensions on the sides that most hitches have to handle the torque applied to the hitch with weight distribution. My conclusion was that the torque from a weight distribution setup would just be too much for the short side arms on the D5 hitch and I was not comfortable with this.
My solution was to install a Tuson Electric Sway Control on the trailer along with a Curt Friction Sway Control. With this setup we have been able to safely tow our Globetrotter through difficult conditions such as high winds, rain and mountain passes. In high winds it is noticeable, and extremely impressive, to feel how the Tuson activates the trailer brakes to control sway. One thing to note for Airstream owners is that Airstream brakes are wired in series which, at least for me, made this not a do-it-yourself installation. My local Airstream dealer charged about $500 for installation which was well worth the price.
Having said this, I am still not happy with the experience of towing a 6000 lb trailer with the D5. While this setup does a good job of controlling side-to-side sway, it does not prevent the up-and-down motion of the back end the vehicle over rough roads. Towing over the undulating pavement of rural Colorado roads for a few hours felt like piloting a small boat over rough seas and made me sea-sick for the first time in my life.
I know there are many comments that Land Rovers do not require weight distribution because of the auto-leveling air suspension. It is true that the auto-leveling does an amazing job of keeping the vehicle level regardless of how much weight is put on the rear end of the vehicle. What is cannot do, however, is distribute some of the hitch weight of the trailer from the rear axle to the front axle, leaving the rear axle to act as a pivot point. This, I believe, is what results in the up-and-down motion that is felt over rough roads.
Finally, the diesel engine in the Td6 is outstanding for towing. I’ve pulled the 6000 lb trailer up steep grades over high elevation mountain passes at highway speeds and the Td6 never struggled at all. The fuel economy of the diesel is also impressive when towing, averaging about 17-18 mpg.
My advice is that if you are towing a trailer weighting around 4000 lbs the D5 Td6 is a great tow vehicle, but if you are getting much above that the inability to use weight distribution becomes a limiting factor. We have decided that for our 6000 lb Airstream it is time to look for something with a higher tow rating that allows the use of weight distribution.
machmike
Thanks for the information and Experience! My 2015 LR4 tows 6k (airstream as well) great without the sway control hitch (I'm in CO as well). Going up the Pudre Canyon I get about 3-5 MPG. Which sucks.
Hedelman4
Pittsburgh PA
Hawkigrad what is the brand of the sway bar? I have 2017 gas engine D5 Discovery and I am pulling a 23 ft dual axel Airstream. I am getting some sway from trucks. Setup is happiest at 55 miles per hour.​
DonC
The Woodlands, TX, US
I am using the anderson. More for sway than weight distribution. The D5 is a fantastic tow vehicle dare i say it but even better than my LR4 with the 5.0 in it. Rock solid at speeds even when being passed by a semi.
A562NV
