Vacuum leak test - 5.0 V8
TrinidadLR4
NE Washington DC
To those who are running the 5.0 LR4 - do you have an easy way to test for vacuum leaks? I think I may have a minor leak, as it's starting to surge and stumble when cold, but not throwing codes. I want to get ahead of it before it gets worse. I have access to an air compressor. Let me know!
scott schmerge
Charlotte, NC
check your pcv valve? Those tend to wear, creating a vacuum leak. Also, dirty throttle body can mimic a vacuum leak.
if pcv valve, spray a little brake cleaner around it and the engine will stumble slightly as it sucks in the cleaner. You can also smoke test it.
TrinidadLR4
NE Washington DC
Thanks, I'll try that. On a few of my previous cars, I was able to lightly pressurize the intake and listen for air leaks. Thought maybe there'd be a similar process for these guys.
PE_in_UAE
