very poor gas mileage
tommy33
I have the same type of issue but I am also getting a P1179 code for air intake module or whatever you call it (other than a $400 part). I clear the fault code and it won't come on again for a week or so.
Would O2 sensor replacement help or should I start thinking about a new mass air sensor.
97 Disco, 66000 miles.
Thanks
Try cleaning the MAF with some electical contact cleaner (remove from vehicle and clean the inside very well, taking time to clean the small part in the center,let it completely dry, then reinstall) I would also clean and use electrical contact grease in the connector.
tommy33
I will try some electrical parts cleaner. I had it apart last week but I was afraid to use it because I didn't know if it would mess something else up.
I'll let you know how it turns out.
Shouls I also replace the O2 sensors? I'm at 66000 miles and I doubt the previous owner did anything maintenance-wise.
Thanks,
You can, I didn't replace mine till around 95k. It depends on fuel economy, type fuel you run, and if cleaning the MAF helps.
tommy33
10-13 MPG. Use Premium fuel. 2 weeks ago new magnacor wires and Bosch Platinum 4 plugs. New air filter, shocks, tires inflated to the proper pressure, synthetic oil in my de-gunked crankcase. Never had any check engine code come up other than P1179. My baby runs fine just lousy mpg. I'll live with it if everything checks out ok.
I am going out to the garage to clean the MAF now and I'll put some contact grease in the plug.
I'll check mpg over thenext week.
Thanks for the tips,
When you say proper tire pressure, are you going off of the LR tire pressure on the door, or something more usefull (I am sure I will get yelled at for that comment). When is the last time you changed the Diff oil (front/rear) MAF will cause poor fuel economy as well.
tommy33
Something more useful-suggestions from this site on proper air pressure.
Changed diff oil and transfer box oil in December.
Cleaned MAF last night and it started right up this morning. I'll give it a couple of days and then check mpg.
Thanks,
tommy33
Either my fuel gauge is broken or cleaning the MAF thoroughly with electronic parts cleaner was a miracle. Went from 30 miles of stop and go driving before the needle dropped to 3/4 to 50 miles of driving. It also seems to be much more responsive. No check engine light on either.
Will do some highway driving too and then check MPG.
Thanks for the tips.
That is what we are here for.... leave the tip an the bar.
tommy33
Hell I'll but a couple of rounds! No Light (Code P1179) after a week and City MPG up from 10 to 14. Seems like it has a bit more pep too.
Thanks again. If this group ever has a round up anywhere anytime soon, I'll be buying a lot of rounds.
Hae79547
