Water Leak
Vin
have a 2002 Disco Series II. I live in the Pacific NW and of course it rains alot. Although it is not raining now, the rain will surely be here soon. When it rains, my seatbelt gets wet and the area (head liner) gets wet above the seat belt holder. I haven't had this problem before, not even when it snows. Is there a drain line that is stopped/clogged somewhere that could be causing the problem?
Vin
Sounds like your Roof Bars are leaking... you may need to remove the headliner and tighten the bolts that hold the bars, or attempt to seal them.
Vin
I hadn't thought of that Joey. It only gets wet above the seatbelt which is wierd. I thought maybe the AC drain lines were/are plugged. I will check both. Thanks
A/C drains are going to cause the floor to get wet.
Sid1577
