What do I do now ??
R
russ00001
I just changed out the battery in my '95 and know the CD changer does not work. In fact I can't even select the CD changer on the radio. After I hooked up the battery, I input the correct code and the radio worked fine. It was only this morning when I wanted to listen to a cd that I found out that it didn't work. The band button works fine, it just won't select "CD"!!! Any Ideas? Thanks in advance.
Can't remember off the top of my head, but there is a fuse that goes to the CD player, and this could very well be your issue. I will look around and see if I can't find it.
R
russ00001
it turned out to be a loose ground wire!! The grounding point was just under the coolant recovery tank. There were about five wires all bolted down together.
Moose
Nice. I love it when the solution is simple. :biggrin:
BCNJ
