Will Check Engine Light Automatically Go Out After O2 Sensor Replaced?
bigbris1
I got a CEL & diagnosed & found it is sensor 2 bank 1.
Once I change it will I have to get the CEL reset or will it go out after I drive 100 miles?
BTW, I found a Bosch replacement O2 sensor at www.racepages.com for $77 shipped.
It may, but normally the fastest way is to clear with an OBDII scanner.
I don't remember the cycles that the ECU has to go through to clear the CEL.
Not sure on the part, but I hope it is the right one... sounds kind of cheap, I looked and they look right.... let us know if it fits, or if you already did this.... any issues. I will save that site as a link
bigbris1
I just replaced it & it is a direct fit, the wires are even the same colors. I'll just drive for 100 miles & see, if not I'll go by my buddy's shop & clear the code.
Thanks!
PanKyiv
