Yes, I have tried that and all appeared fine. If i can recall...sitting idle was about 12.45v, when I started it, volts drops momentarily to around 11v or so, once started it is around 13+ volts. I was wondering, is it possible to spray starter fluid on these LR3's, like we use to do to carburetor cars?
What do you mean , it reads 13+ volts?. Good working alternator should pull, under load, at least 14.25 and up...A brand new battery should read 12.60( six cells, each cell 2.1 volts=12.6.your alternator might be failing slowly , if it is only above 13 V, that is too low, as it should produce almost two volts more, when working ..just a thought...
