Air Bag (suspension) Rubber cover/sleeve.
aragno
Hello... first post (and yes I have searched :) ) for this topic but no luck.
I have a 2006 LR3 V8 HSE - no mods.
If you look at the rear airbag of the suspension you will see a metal tube which extends when the airbag inflates. It is then having a rubber "sleeve" of sorts.
Anyone know how to replace this?? Mine is damaged (some parts of stuck inside the meal tube I mentioned above) and on others simply torn.
Thanks!
-Trey
Trynian
If you are talking about the rubber gator dust cover it costs about $70 and is an easy job to replace but you have to release the air in the bag.
Lower the car to acess let it go to sleep. jack up the so that wheel hangs down. Undo the shock bolt at bottom. release the air in the shock by loosening the green line going in at the top.
You can then slide the new boot on. It come in two pieces one for the top and the big one at the bottom. It is easy to slide the top one up into place since it stretches. There is a metal clamp that you need a special tool for that you can get at any auto store. You can also tighten it with a pare of dikes but the tool works better. If it comes with a lower clamp leave that off it will just cause it to get caught again in the air shock. I think the new ones dont have it in the kit.
bbyer
Alberta
Disconnect the battery as well.
Whenever I jack up my 3 to kind of get under it or fool with the air suspension, I remove the negative battery cable.
Doing this seems to pretty much **** the air system release valves and more importantly the auto level program that goes into play when the ignition is off.
The auto level function seems to have a random wakeup ability and when it senses the jacking, it often reacts by releasing air, and sometimes not, and that is the real problem - not predictable.
You should notice an air release when after you have finished, removed all your jacks and supports, that when you connect the battery back up, within seconds, (the time it takes for the computer to wake up), there is a loud hiss and the 3 settles, sometimes a little, sometimes alot. That is why you want to have everything out from under the 3 including yourself.
aragno
I believe this is precisely what I am talking about. Any clue what part number is or a place to purchase online?! Thanks for you quick assistance.
Trynian
The part number is 5B752A I got mine from the dealer, I don't know if it is available online anywhere other then a dealer online service like http://saclandrover.niello.com/parts.php
You just have to send a parts request.
Old thread but I didn't find it to be fully exhaustive on info. I was only able to find one item online and it's not the "genuine" part. Not that oem isn't good enough, but I do like to find both for comparing. I'd rather do this only once in 100k miles, not more times for a cheaper part made to lesser quality.
http://www.ebay.com/itm/141470821201
tlt
Yup, it is two years old, and the ebay link will be expired in weeks. Are you looking for parts?
Knucklehead question but is this an internal part to the original struts that they all came with from the get go?... Or is this an upgrade that some have elected to purchase?
