- Joined
- Feb 8, 2011
- Posts
- 3,401
- Reaction score
- 96
Confirm 2013 TPMS & Spare Tire Advice Needed
Hello Everyone,
So, my five (5) 18" Compomotive wheels (satin black) arrived at my local independent Land Rover garage, and upon close inspection, a big chip was found in one of the wheels. Ugh!
I e-mailed Barry at Compomotive a photo of the chipped wheel this afternoon (the shipping box seemed fine), so I am hoping I can exchange it for another wheel relatively easily (as long as there is one in stock
). I will keep you all posted as to his response. So far he's been extremely responsive and helpful.
After a lot of research for my needs, discussions with lots of people, and personal preference, I have decided to go with the BF Goodrich A/T KO tires in the 265/65R18 size. Going with this size will allow me to run the tires at standard height with no modifications needed. There may be slight rubbing at full rear wheel lock (not enough to require re-routing A/C, heating, sensor lines), but that can be remedied when the tire wears in a little or you can remove the plastic wheel lining and bend in the metal a bit (that is supposedly where it rubs). I have instructions from Gordon at Green Oval who has a lot of experience with these wheels and various tire sizes/types.
I am planning to get 5 TPMS and want to confirm these are the correct ones for a 2013:
http://www.tpmsdirect.com/Land_Rover_LR4_TPMS_Sensor_p/1055-20.htm
I want 5 TPMS because I plan to rotate my 18" wheels/tires as factory recommended, even the spare.
Now my question about my spare. I have the HD package with the full-sized spare (it is black to match my other stock black design wheels). I currently have that factory full-sized wheel with the stock Conti tire stowed away, and when I go off-roading, I throw in another spare (silver LR4 wheel) I have with a Cooper Zeon LTZ tire. I also have Cooper Zeon LTZs on my current other four wheels.
I am thinking of switching the Cooper tire from the silver 19" wheel to the stock black spare 19" wheel and then keeping my 5 stock black 19" wheels with Cooper Zeon LTZ tires (and they will all have the stock TPMS). This way I can switch back to the 19" wheels if I wanted with no problem. I was thinking of mounting my stock spare Conti (and TPMS) on the 19" silver LR4 wheel (I bought this on eBay last year) and stow that under the truck to keep it as an emergency back-up donut tire. Plus, it would prevent my TPMS alert from going off since it's stowed and aired up. I would only use the spare 19" wheel/Conti tire as an emergency temporary spare at low speeds if something happened to my 18" spare. I am planning to put my 18" Compomotive spare wheel with BFG tire on the roof rack full-time and use that if needed. Do you think this will work or would it be terrible to possibly (but highly unlikely since I will have the 18" spare on the roof rack) ever use the 19" Conti as a back-up very short-term donut spare?
Let me know your thoughts. Thanks!
-David
Hello Everyone,
). I will keep you all posted as to his response. So far he's been extremely responsive and helpful.After a lot of research for my needs, discussions with lots of people, and personal preference, I have decided to go with the BF Goodrich A/T KO tires in the 265/65R18 size. Going with this size will allow me to run the tires at standard height with no modifications needed. There may be slight rubbing at full rear wheel lock (not enough to require re-routing A/C, heating, sensor lines), but that can be remedied when the tire wears in a little or you can remove the plastic wheel lining and bend in the metal a bit (that is supposedly where it rubs). I have instructions from Gordon at Green Oval who has a lot of experience with these wheels and various tire sizes/types.
-David
